e-Gov
pagina n.8
Pagina 8: pagina n.8
FIC, continua
Easy to see: The motherboard is installed in the middle of the cylinder.
La motherboard è inserita la centro del cilindro
The Condor is a new Mini-PC that builds on conventional components. The design is comparatively easy on the eye, and the internal structure is fairly innovative.
Il Condor è il nuovo Mini-Pc basato su componenti convenzionali
Simplifying maintenance, the Condor can be opened sideways. Beyond that, there's the option of using an AGP graphics card which matches the enclosure*s height.
Il design semplifica la manutenzione
Fishhawk is yet another mini bare bone, which dazzles users with its two 80 mm side ventilators. They serve the purpose of keeping noise levels low, a claim that is difficult to verify when there's CeBIT noise all around us.
Fishhawk è un altro barebone che permette un utilizzo in verticale
Indice
