- 57
- 9
- CPU
- i7 4790
- Dissipatore
- dissipatore stock
- Scheda Madre
- h81m-dgs r2.0
- HDD
- 1tb WD blue + ssd samsung da 250gb
- RAM
- 8gb ddr3 1600 mhz
- GPU
- 1060 3gb asus
- Monitor
- benq gw2270 60hz
- PSU
- 600w
- Periferiche
- scheda wlan tplink N900
- OS
- windows 7
warning: [options] bootstrap class path not set in conjunction with -source 1.6
C:\Pylo\MCreator171\forge\build\sources\main\java\mod\mcreator\mcreator_bioma.java:26: error: method setWaterColor in class BiomeProperties cannot be applied to given types;
customProps.setWaterColor();
required: int
found: no arguments
reason: actual and formal argument lists differ in length
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
1 error
1 warning
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':compileJava'.
> Compilation failed; see the compiler error output for details.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
required: int
found: no arguments
1 error
1 warning
* What went wrong:
* Try:
