Salve , sto cercando di visualizzare un cubo utilizzando webGL , purtroppo anche seguendo i vari passaggi di costruzione non capisco perchè quando apro l'html per visualizzarlo il canvas appare bianco e il cubo non è presente . Qualcuno saprebbe aiutarmi ? Posto qui il codice :
HTML
JavaScript
HTML
HTML:
<!DOCTYPE html>
<html>
<script id="vertex-shader" type="x-shader/x-vertex">
attribute vec4 vPosition;
attribute vec4 vColor;
varying vec4 fColor;
void main()
fColor = vColor;
gl_Position = 0.5 * vPosition;
</script>
<script id="fragment-shader" type="x-shader/x-fragment">
precision mediump float;
void
main()
gl_FragColor = fColor;
</script>
JavaScript
JavaScript:
"use strict";
var canvas;
var gl;
var NumVertices = 36;
var points[];
var colors[];
var delay = 100;
window.onload = function init()
canvas = document.getElementById( "gl-canvas" );
gl = WebGLUtils.setupWebGL( canvas );
if ( !gl ) { alert( "WebGL isn't available" ); }
colorCube();
gl.viewport( 0, 0, canvas.width, canvas.height );
gl.clearColor( 1.0, 1.0, 1.0, 1.0 );
gl.enable(gl.DEPTH_TEST);
// Load shaders and initialize attribute buffers
var program = initShaders( gl, "vertex-shader", "fragment-shader" );
gl.useProgram( program );
var cBuffer = gl.createBuffer();
gl.bindBuffer( gl.ARRAY_BUFFER, cBuffer );
gl.bufferData( gl.ARRAY_BUFFER, flatten(colors), gl.STATIC_DRAW );
var vColor = gl.getAttribLocation( program, "vColor" );
gl.vertexAttribPointer( vColor, 4, gl.FLOAT, false, 0, 0 );
gl.enableVertexAttribArray( vColor );
var vBuffer = gl.createBuffer();
gl.bindBuffer( gl.ARRAY_BUFFER, vBuffer );
gl.bufferData( gl.ARRAY_BUFFER, flatten(points), gl.STATIC_DRAW );
var vPosition = gl.getAttribLocation( program, "vPosition" );
gl.vertexAttribPointer( vPosition, 4, gl.FLOAT, false, 0, 0 );
gl.enableVertexAttribArray( vPosition );
render();
function colorCube()
quad( 1, 0, 3, 2 );
quad( 2, 3, 7, 6 );
quad( 3, 0, 4, 7 );
quad( 6, 5, 1, 2 );
quad( 4, 5, 6, 7 );
quad( 5, 4, 0, 1 );
function quad(a, b, c, d)
var vertices = [
vec4( -0.5, -0.5, 0.5, 1.0 ),
vec4( -0.5, 0.5, 0.5, 1.0 ),
vec4( 0.5, 0.5, 0.5, 1.0 ),
vec4( 0.5, -0.5, 0.5, 1.0 ),
vec4( -0.5, -0.5, -0.5, 1.0 ),
vec4( -0.5, 0.5, -0.5, 1.0 ),
vec4( 0.5, 0.5, -0.5, 1.0 ),
vec4( 0.5, -0.5, -0.5, 1.0 )
var vertexColors = [
[ 0.0, 0.0, 0.0, 1.0 ], // black
[ 1.0, 0.0, 0.0, 1.0 ], // red
[ 1.0, 1.0, 0.0, 1.0 ], // yellow
[ 0.0, 1.0, 0.0, 1.0 ], // green
[ 0.0, 0.0, 1.0, 1.0 ], // blue
[ 1.0, 0.0, 1.0, 1.0 ], // magenta
[ 0.0, 1.0, 1.0, 1.0 ], // cyan
[ 1.0, 1.0, 1.0, 1.0 ] // white
// We need to parition the quad into two triangles in order for
// WebGL to be able to render it. In this case, we create two
// triangles from the quad indices
//vertex color assigned by the index of the vertex
var indices = [ a, b, c, a, c, d ];
for ( var i = 0; i < indices.length; ++i ) {
points.push( vertices[indices[i]] );
//colors.push( vertexColors[indices[i]] );
// for solid colored faces use
colors.push(vertexColors[a]);
function render()
gl.clear( gl.COLOR_BUFFER_BIT | gl.DEPTH_BUFFER_BIT);
gl.drawArrays( gl.TRIANGLES, 0, NumVertices );
