Immagine di Recensione Fritz!Mesh Wi-Fi Set 1600, il mesh da abbinare al proprio router Recensione Fritz!Mesh Wi-Fi Set 1600, il mesh da abbinare al...
Immagine di Samsung raddoppia i prezzi della RAM DDR5 Samsung raddoppia i prezzi della RAM DDR5...
Dal Web: driver, BIOS, Firmware e utility
Avatar di Manolo De Agostini
a cura di Manolo De Agostini
Pubblicato il 06/06/2005 alle 13:39 - Aggiornato il 15/03/2015 alle 01:04
Rilasciati nel corso del weekend nuovi BIOS, Firmware, driver e utility.
- ATI Tray Tools Build 1.0.2.685
Software highlights:
  • Support for ATI Control Center
  • Support for TV Out and displays with profiles
  • Options to change Theater mode together with TV Out
  • Overclocking with templates including FAN Control
  • Automatic overclocking when application required 3D mode
  • Temperature monitoring
  • Artifact Tester with ability to find maximum stable clocks for GPU and Memory.
  • Game profiles with desktop shortcut creation.
  • Direct3D settings with templates, GUI form and tray popup menu
  • OpenGL settings with templates, GUI form and tray popup menu
  • Hardware low level color correction
  • Hardware tweaks. Setting PCI latency timer
  • Radeon Information Show information about memory type, active rendering pipe lines and more
  • System wide Hot Keys. (Load profiles any profiles/work with colors/run any application)
  • Refresh Lock system with ability to set separate refresh rates for each resolution.
  • Tweak for overriding Pixel and Vertex Shaders
  • Speed improvement tweaks for Anisotropic/Trilinear Filtering. Support for Catalyst A.I.
  • Support for system options, VPU Recover, DMA Copy and so on
  • Support Display Rotation.
  • Support for MMC applications
  • Support for HYDRAVISION applications
  • Monitoring Graphs. (GPU/Env temperature. GPU/Mem speed, Main CPU Usage).
  • A lot of useful things. Like Save/Restore Desktop icon positions and more
  • Audio Recorder
  • Screenshots system
  • Powerful Plug-Ins support. (API for VC++/Delphi included)
  • PCI Register Set. Allow to program any registers in any PCI device at start up time. For advanced users only!
  • Source code for plugins as examples.
Supported OS: Windows 2000, Windows XP, Windows 2003
Windows 9x/ME is not supported!
- DNA-ATi 3.10.5.5 & LITE
VERSION:: DNA-ATi 3.10.5.5 / DNA-ATI 3.10.5.5-LITE
* B ased on the official CATALYST 5.5 release
* N o DNA-ATi Themes ( will be back in the next release )
* U pdated DNA-ATi OpenGL Changer to version 1.4
- and added the Catalyst 5.5 2nd OpenGL file
* U pdated / A dded support for:
- ALL-IN-WONDER X800
- ALL-IN-WONDER X800 VE
- RADEON X800
- RADEON X800 PRO
- RADEON X800 XL
- RADEON X800 XT
- RADEON X850 PRO
- RADEON X850 XT
- RADEON X850 XT Platinum Edition
* U pdated internal modded driver deletion ( more clean way )
- and deleted some internal ( installer ) double entries
* U pdated DNA-ATi Theme Changer to version 1.4
- and fixed eXp theme not installing
* D eleted ATi Tray Tools from the package
- users can download ATi Tray Tools if they need it
* U pdated installation screens (less screens to click trough)
* U pdated and renewed resolutions:
- Added: - 960x720 // 1024x600 // 1280x600 // 1280x720 //
- 1280x768 // 1280x800 // 1280x960 // 1360x768 // 1360x1024 //
- 1600x1000 // 1600x1024
- Updated Large Desktop Modes: - 3840x2400 // 3200x1200 //
- 2800x1050 // 2560x1024 // 2304x864 // 2048x768 // 1600x2400 //
- 1600x600 // 1400x2100 // 1280x2048 // 1280x480 // 1152x1728 //
- 800x1200 // 640x960
- Deleted: - 1520x1140 // 1360x1020 // 1200x900 //
* F ixed OpenGL problems ( games giving error messages )
* U pdated modded driver deletion for:
- Radeon Omega Drivers v2.6.25
- Radeon Omega Drivers v2.6.12
- Radeon Omega Drivers v2.5.97a ( updated )
- Radeon Omega Drivers v2.5.97 ( updated )
- Radeon Omega Drivers v2.6.05a ( updated )
- Radeon Omega Drivers v2.6.05 ( updated )
- ATI Optimized Driver by TechConnect Magazine v2.5
- ATI Optimized Driver by TechConnect Magazine v2.4 ( updated )
- ATI Optimized Driver by TechConnect Magazine v2.3 ( updated )
- ATI Optimized Driver by TechConnect Magazine v2.2 ( updated )
- ATI Optimized Driver by TechConnect Magazine v2.1 ( updated )
- ATI Optimized Driver by TechConnect Magazine v2.0 ( updated )
* R emoved OpenGL install screen, the OpenGL file can easily be swapped
- with the DNA-ATi OpenGL changer from the DNA-ATi start-menu shortcut
- the Normal OpenGL file will be installed by default
* A dded the option to install the driver with AGP Fast Writes Disabled
- (Fast Writes can be turned on/off from the DNA-ATi start-menu shortcut)
* A dded new DNA-ATi optimization profiles
+ Switch between optimization options on the fly: ( let the COPY war begin )
+ SWRC ( new Star Wars: Republic Commando profile )
+ IQ ( new Image Quality profile )
+ Pariah ( new Pariah profile )
+ First To Fight ( new First To Fight profile )
+ Riddick ( new The Chronicles of Riddick - Escape From Butcher Bay profile )
+ Kotor ( new Star Wars: Kotor 1&2 profile )
+ FarCry ( new FarCry profile )
+ Halo ( new Halo profile )
+ NFSU-2 ( new NFSU-2 profile )
+ Aquamark ( new Aquamark profile )
+ The profiles can be accessed from the DNA-ATi start menu shortcut
* U pdated Readme:
- Addded Q&A section ( Will be updated frequently )
- Updated fonts type / and colors
VERSION:: DNA-ATI 3.10.5.5-LITE
* No WDM Drivers
* No DNA-ATi Themes
* No DNA-ATi OpenGL Changer 1.4
* No DNA-ATi Theme Changer 1.4
* No Special Counter-Strike OpenGL and CATALYST 5.5 2nd OpenGL driver
* No ATi Temporal AA Switcher
* No OLD Style Control Panel install option
- nVidia Linux Display Driver 1.0-7664
  • Added OpenGL 2.0 Support.
  • Added initial support for Xinerama + OpenGL; see APPENDIX V in the text README.
  • Added support for the EXT_framebuffer_object OpenGL extension.
  • Added NV-CONTROL support for manipulating DDC/CI settings; see the AllowDDCCI X config option in the text README.
  • Added support for GPU clock manipulation; see the "Coolbits" X config option documented in Appendix D.
  • Added support for NVIDIA Quadro G-Sync.
  • Added support for GeForce 6200 AGP.
  • Improved DPMS behavior on flatpanels.
  • Removed support for legacy GPUs; please see "Chapter 1. Selecting and Downloading the NVIDIA Packages for Your System" in the README for details.
  • Install NVIDIA OpenGL headers by default.
Driver nVIDIA per Linux i386 e x86 64.
- 50 BIOS updates for Week 22 @ PCTuning.cz
Marche coinvolte:
- Albatron (7×), AOpen (8×), Asus (8×), Chaintech (4×), DFI (1×), ECS (1×), Iwill (2×), Jetway (4×), MSI (2×), Shuttle (7×) Soltek (4×), Tyan (2×).
- 6 FIRMWARE updates for Week 18 @ PCTuning.cz
- Btc (3×), Samsung (3×)
ChatGPT sfida Nano Banana: arriva il nuovo generatore d'immagini
AMD Ryzen 7 9850X3D sempre più reale, spunta in un negozio online
TV da 350€ con Ambilight di Philips? Ora è possibile grazie a questa offerta
