Nella giornata di oggi sono stati rilasciati alcuni aggiornamenti per programmi e driver comunemente utilizzati. Il primo software aggiornato è ATiTooL, noto programma per l'overclocking delle schede ATi.
Changes in this version:
- Registry keys changed, you will lose your settings once, when upgrading
- When multiple ATI cards are installed, you can now select the one to use
- Crash issues when returning from standby/hibernate with Catalyst 4.8+ fixed
- Added Memory Timings options to profile
- Added Gamma options to profile
- Added option to control artifact detection sensitivity
- ATITool will now try to use the D3D device which matches the active card
- Temperature monitoring and fan control works on X800 AIW now
- Added thermal monitoring support for X800XL
- Added "Do not change PWM frequency" switch for X850 fan control
- Added support for some new X850 boards
- Fixed temp. monitoring on X850
- Fixed fan control noise on X850
- Added support for R420GL
- Fixed AMD64 issues
- Added option "Beep on artifact"
- Fixed crash issue when opening Memory Timings Editor window more than once
- Fixed memory timings editor's MEM_TRFC extra options with garbled characters after the list of correct options
- Completely rewritten Kernel Mode Driver, it's no longer a legacy NT4-style driver
- Default profile always in list, even when profiles.ini does not exist
- Fixed incorrect log output when artifact detected during scan for artifacts
- Added refresh rate fix
- Warning displayed when "Alternate Pixel Center" is enabled
- ATITool can now be removed via Control Panel, Software
- Fixed some issues when running on systems without ATI card
- Added warning when not installing as Administrator
- Fixed problems when using ATITool on RS480 motherboard
- Fixed problems when using ATITool with RIO550 tv card
- Added Geometry Instancing option
- Removed annoying logging message from log file
- Video card detection problem fixed (bus# > 8)
- Fixed possible race condition in overclocking/scanning code
- Fixed memory timings crash for R480
- Safety frequency range is now filled with current values when enabled for the first time
Disponibile inoltre un set di driver per nForce 4 Intel Edition.
Release Notes:
- WHQL candidate
- Standalone drivers for use on nForce4 SLI Intel Edition products, including dual-processor systems.
- Added support for NVIDIA Disk Alert System and RAID5
- General compatibility fixes
Windows XP Driver Versions:
- Audio driver 4.62 (WHQL)
- Audio utilities 4.51
- Ethernet driver 4.82 (WHQL)
- SMBus driver 4.45 (WHQL)
- Installer 4.72
- IDE NVIDIA driver 5.33
Download nForce4 SLI Intel Edition 7.11
Intel ha rilasciato nuovi driver WHQL per i propri chipset. Nel download anche i modelli supportati.
Features:
- Core PCI and ISA PNP Services
- AGP Support
- IDE/ATA33/ATA66/ATA100 Storage Support
- USB Support
- Identification of Intel Chipset Components in the Device Manager
This is a BETA driver, not a final. You use this at your own risk ! Supported by Windows 2000/XP/2003. This release adds Intel i9xx Serie / E8xxx Serie support.
