Disponibile un fix per il benchmark AquaMark3. Per la procedura di installazione leggete qui sotto, per il download cliccate qui.
[10.11.2004] A new version of Direcpll.dll file is available for download! This file is recommended to properly run AquaMark3 with some newer graphics hardware. It fixes problems like black screens, exceptions/access violations and incorrect clock speed detection.
In order to update your file, you should download direcpll-153.zip (34kb), then locate your AquaMark3 directory (e.g. C:Program FilesAquaMark3), backup the original "direcpll.dll" and finally unpack the downloaded .zip file into your AquaMark3 directory, overwriting "direcpll.dll".
