Connettori di Alimentazione e Standard ATX
Nelle seguenti tabelle trovate vari tipi di connettori per l'alimentazione.
Connettore per il collegamento delle periferiche
AMD | |
Socket 462 | |
Power Supply Standard | ATX12V 1.3 or higher |
ATX plug | 20-pin |
AUX plug (6-pin) | not used |
P4 connector (4-pin 12V) | rarely used |
Socket 754 | |
ATX plug | 20-pin, sometimes 24-pin |
P4 connector (4-pin 12V) | sometimes needed |
Socket 939 | |
Intel | |
Socket 370 | |
ATX plug | 20-pin |
AUX plug (6-pin) | rarely used |
Socket 423 | |
ATX plug | 20-pin |
P4 connector (4-pin 12V) | needed |
Socket 478 | |
ATX plug | 20-pin |
P4 plug (4-pin 12V) | needed |
Socket 775 | |
Power Supply Standard | ATX12V 2.01 or higher |
ATX plug | 24-pin, sometimes 20-pin |
AUX plug (6-pin) | n/a |
P4 plug (8-pin 12V) | 945X chipset (DualCore) or higher often needs this connection |
ATX-Stecker 24-pin (Extented ATX) Connettore scheda madre ATX a 20-pin Cavo ATX a 20 pin Connettore EPS a 6 pin
